[VAGcom] Coming Home - Leaving Home: Automatique
wolrod
Re:
Message par wolrod »
mloft a écrit :Bonsoir. Pour ma part Coming-Home toujours pas opérationnel. J'ai trouvé d'autres sources d'infos, notamment celle-ci qui synthétise pas mal de manip. réalisable: http://forums.thecarlounge.netzerothread
Voici ce qui est dit précisément pour activer le coming-home en bas de page:
Enabling Coming Home/Leaving Home (CH/LH) on NA SE models, thanks RJB!!
The first step is to enable the convenience menu--see above.
Now, there are five places to verify in module 9 (central electronics). Use the long coding helper.
1. Byte 00/bit 5: assistance driving light & leaving home active--set this bit to 1 for active
2. Byte 00/bit 7: coming home active--set this bit to 1 for active
3. Byte 02/bit 4: coming home mode via--set this bit to 0 for personalization
4. Byte 21/bit 6: leaving home variant--set this bit to 0 for LH in LDS
5. Byte 23/bit 5: coming home logic--set this bit to 1 for new logic.
Once these coding changes are made, go into the convenience menu and select the lighting sub-menu. Here you will find coming home and leaving home settings. Select each and set the time in seconds (10 sec intervals) that you want the lights to remain on.
Once these changes are made, the functionality for a 2009 NA Tiguan SE with two-position light switch in the off position (factory switch--no need to change) is as follows. Unlock the vehicle with the remote--the lights will come on and remain on for the duration chosen in the convenience menu or until the vehicle is started. Upon arriving, turn off the ignition and if it is dark, turn off the headlamps. Remove the key from the ignition and give a quick pull to the lamp stalk--the high beams will flash. Upon opening the door, the exterior lights will come on. Lock the car with the remote and the lights will remain on for the duration selected in the convenience menu.
Salut à tous, je remonte ce topic pour essayer de m'en sortir : je n'ai pas les bytes 21 et 23 d'accessibles sur mon touran de 2004.... que puis-je faire pour y accéder ?
Tout le reste est bon....
merci...
"L'intelligence c'est comme les parachutes : quand on n'en a pas, on s'écrase !"
vw34
Re: allumage auto des feux lors de la fermeture (coming home
Message par vw34 »
Désoler pour se déterrage mais je trouve pas de réponse a mon interrogation . Je voudrait mètre les AB en coming home , living home et non pas les feux savez vous comment faire .!!??? J'ai un V3
Cédric974
Message par Cédric974 »
VAG-COM
topic18886.html
vw34
Message par vw34 »
Cédric974 a écrit :VAG-COM
Jmen doute mais j'ai pas trouver de tuto ou de truc dans se genre .!!!
D ailleurs dommage que se forum n'ai pas de section tuto ( électrique , mécanique et vag com )
Cédric974
Il faut fouiller un peu sur le net,il y as une section VAG-com sur le fofo
Ensuite il me semble fortement qu'en farfouillant dans mes calculateurs j'ai vu l'option,par contre je ne sait pas si mon câble tourne sur un modèle 2012,au pire si tu viens au prochain rasso on peut regarder ça si tu ne l'as pas déjà fait...
topic18886.html
vw34
Message par vw34 »
Ok sa marche , déjà faut que je trouve un vag com en français en en british c est pas formidable .!!!
farnouche
Message par farnouche »
va voir le post "modif electronique"
j'y ai mis le bit a changer pour passer le code à AB avant en CH/LH
Dommage que ça ne fonctionne pas sur un V2... :-?
vw34
Message par vw34 »
farnouche a écrit :va voir le post "modif electronique"
Je me suis taper les 11 pages et a part un fichier marquer en vert rien trouver de concret donc Jvai voir plus tard dommage , j'aime pas avec les feux en CH LH.
Cédric974
tomcat92 a écrit :Dommage que ça ne fonctionne pas sur un V2... :-?
Tu est sur ? Tu me met le doute,à vérifier...
Je sait qu'on peut mettre les feux de croisement en FDJ,ça c'est sur je l'ai fait par erreur....
topic18886.html
Re: RE: allumage auto des feux lors de la fermeture (coming
On peut faire plein de trucs mais pas mettre les AB en coming home :-(
Enfin, je n'ai jamais trouvé en tout cas...
farnouche
farnouche a écrit :bit 3 octet 17
post382258.html#p382258
:bizz:;
Pour les V3...
farnouche
tomcat92 a écrit :Pour les V3...
of course :marr:
